Locked 1 post Page 1 of 1
Beta 16 released!
    Beta 16 released!
    by Pierre Guilluy » Thu Nov 30, 2017 6:03 pm
    Hi Modul8 users!
    Here comes Modul8 v3 Beta 16 with support of NDI output!
    You can send Modul8 outputs to MadMapper running on a remote Mac or PC, or basically any application that supports NDI sources, including Modul8 itself.
    No configuration is required: simply activate Output --> Syphon / NDI and your outputs are available to all NDI-compatible application connected on the same network.
    Release Notes:
    Version v3 BETA 16 build171130_D2E7DBCC5 (expiration date January, 31st 2018)
    v3 requires macOS 10.9.5+
    ADDITIONS
    - Added support for NDI output coupled with Syphon output (64-bit only)
    FIXES
    - Fixed a crash when switching Advanced Output
    - Fixed a problem with SUB blend mode wrongly rendering through Syphon / NDI
    - Fixed Lightness not being applied to all outputs
    - Fixed NDI sources naming
    Modul8 3.0 is an universal app, meaning it contains both 64 and 32-bit binaries.
    By default it runs in 64-bit mode to take advantage of the full system's memory.
    To put the app in 32-bit mode and benefit from the legacy features, press cmd+I on Modul8.app and check "Open in 32-bit mode" in the information window.
    This Public Beta version is available from today for any users who own a serial which is compatible with modul8 2.9.xx.
    To download it, use the modul8 yourspace page :
    http://www.modul8.ch/yourspace/
Users browsing this forum: Bing [Bot] and 1 guest
