Locked 27 posts
MadLaser BETA available
    Re: MadLaser BETA available
    by mad-matt » Mon Nov 01, 2021 12:05 am
    Last night tried it on PC, it runs like a charm. I tested with Etherdream and Helios, everything is allright.
    On mac 10.13.6 it crashes on exec. MM dont open at all. Any idea?
    Yes, there's an issue with a library we're using on 10.13 or earlier. We solved that, I'll pm you a new build. We should make a beta 2 next week I suppose, just waiting for more feedback.
  • cjmsupportnl
    by cjmsupportnl » Mon Nov 01, 2021 10:00 pm
    i was trying to get it to work but sadly it will not for now
    setup
    beyond advanced
    madmapper beta
    tarm 5 with fb4
    setup zone 1 in beyond to be save
    setup projectie output works
    setup laser output i can select the pangolin zones
    show laser cursor not working etc
    some one already have it working ?
  • sputnik
    by sputnik » Mon Nov 01, 2021 10:50 pm
    Hi, what portable laser would you recommend or have tested , and be compatible with MM5 ? I was looking at LaserCube by Laseros.com as want to travel with it , but understand it is different protocol ? Sorry , still kinda noob in laser environment . Another thing is DAC. Have noticed that Helios is the way to go..
    by Pierre Guilluy » Tue Nov 02, 2021 10:01 am
    Yesterday I was able to download the Mac and PC betas. I had to update my osx since I was still in high sierra, now from Big Sur I can't get past the login, I'm sure to write my username and pass correctly, but it indicates an error all the time. In the link to forgotten password open https://beta.madmapper.com/ and from there it does not happen ... I'm in a loop!
    is there a problem with the page?
    As for MadMapper 5, the new website & licensing system are all in beta, therefore still prone to hiccups.
    You should now be able to log back in and try MadMapper 5.
    by Pierre Guilluy » Tue Nov 02, 2021 11:34 am
    Thanks for this GIANT upgrade <3 this will drive things to another insane level!!
    i followed your instructions, but i can only download this:
    is that right? thank you!
    What would you like to download other than the MadMapper 5 Beta installers?
  • allexandre
    by allexandre » Tue Nov 02, 2021 3:53 pm
    I understood that the DAC as Ether Dream and Helios filter the whole data and decrease the laser performance (scanning).
    If this is true, I would like to know if using showNET directly from MadLaser is therefore more performance than using ether Dream and Helios DAC ?
    Best
    by franz » Sun Nov 07, 2021 10:34 pm
    Shownet : 12bit precision
    Helios : 12bit precision
    Etherdream: 16bit precision
    End of the day, one can tell the differences in realife only in very specific situations/ content.
  • joapalmer
    by joapalmer » Tue Nov 23, 2021 8:02 pm
    Will MadLaser support BeamBrush laser technology?
  • pka_pka
    by pka_pka » Wed Nov 24, 2021 1:45 pm
    I´ve had the beta running in Bootcamp Windows, with 1 Etherdream, 1 Helios, and pipe to a bunch of Pangolin Beyond zones.
    Clicked like a madman everywhere, tried to click and drag interface stuff that shouldn't be dragged, had 40-ish surfaces and paramenters animated via audio, weather data, MIDI and OSC from Vezér, input from hardware controller, Padmapper vectoring live camera input AND pushing video + a bunch of Artnet fixtures.
    Could not make it crash.This will be life changing technology for my use :)
  • ProjectileObjects
    by ProjectileObjects » Fri Nov 26, 2021 8:09 pm
    Kind of wish MM would have told us in advance that the MadLaser license was going to be an additional fee. I wouldn't have bought the Etherdream for $199 for experiments only to find out I'd have to spend another $250 to use in in MM.
  • timbrass
    by timbrass » Sat Nov 27, 2021 5:01 pm
    Helios is cheaper + no psu needed as it is USB powered ...
    However, Helios is 12bit precision vs 16bit Etherdream.
    I'd still go for Helios tho'
    Is there a URL to the Helios product?
  • timbrass
    by timbrass » Mon Nov 29, 2021 2:23 pm
    Amazing! Anyone got a quick suggestion for a simple laser setup for testing this stuff?
    Ether Dream or Helios?
    Laser recommendation?
    Thanks.
    I have ordered a Helios DAC, ILDA cable and a Laserworld CS1000RGB Mk3 laser (about £540 inc MadLaser). I will let you know whether it works.... Currently playing with imported animated GIFs (running man type thing) and displaying them as laser images.
Locked 27 posts
