Modul8 compatible with macOS Ventura
  • burakaltun1
    Re: Modul8 compatible with macOS Ventura
    by burakaltun1 » Mon Dec 19, 2022 7:16 pm
    Lte clip control
    Black flash
    Could you be more specific?
    You can record the actions leading to the menubar not working.
    The idea is that we can reproduce your issue, which will greatly help fixing it.
    Just install the plugin from the online library. The menu bar is locked. I'm telling you something very simple. Install the plugins, restart the module8 and the menu bar won't work.
  • burakaltun1
    by burakaltun1 » Wed Dec 21, 2022 11:55 am
    Lte clip control
    Black flash
    by Pierre Guilluy » Wed Dec 21, 2022 12:18 pm
    I could reproduce the problem once right after having install those two modules.
    After the install, I quit Modul8, save the new modules when asked, and finally when I restarted Modul8 the menubar didn't work.
    After I cleared the preferences using Modul8 Preferences Smasher, it all went back to working as normal, and I never could reproduce the problem once again.
    Did you have a similar experience using 3.1.12 on Ventura?
  • burakaltun1
    by burakaltun1 » Thu Dec 22, 2022 2:26 am
    Do you have a suggested solution?
    by Pierre Guilluy » Thu Dec 22, 2022 12:05 pm
    For me the problem only happened right after the module was installed.
    Once using the Preferences Smasher, the modules remain in the application, but the menubar was working back.
    Please let me know if your experience is the same as I described.
  • burakaltun1
    by burakaltun1 » Sat Dec 24, 2022 6:54 am
    I don't know how to use Preferences Smasher.
    by Pierre Guilluy » Sat Dec 24, 2022 11:27 am
    I contacted you by email.
  • burakaltun1
    by burakaltun1 » Sat Dec 24, 2022 5:38 pm
    burakaltun1@gmail.com
  • burakaltun1
    by burakaltun1 » Fri Jan 06, 2023 4:59 pm
    I think it needs a decent update. The plugins that I have installed from the online library sometimes play and sometimes the top menu is locked.
  • Balgrim
    by Balgrim » Fri Jan 13, 2023 2:23 pm
    I got exactly same problem as barakaltun1 described. MacOs Ventura/M1max
    And don't know what you mean/use to perform "Preferences Smasher".
    step1 : install the update (3.1.12)
    step2 : open Modul8, add a layer, open Module Library online
    step3 : add "Polygon Paint.m8m
    step4 : close project and save module
    step5 : open saved project, then got "menubar" issue
    by Pierre Guilluy » Mon Jan 16, 2023 10:11 am
    @Balgrim & @burakaltun1
    I've reached you by email with a new test build that should address your issues.
    We'll provide an update if the fix proved successful.
  • burakaltun1
    by burakaltun1 » Sat Jan 28, 2023 4:45 pm
    problem solved. If it repeats, I will write
    by Pierre Guilluy » Mon Jan 30, 2023 4:23 pm
    @burakaltun1 thanks for the feedback.
  • burakaltun1
    by burakaltun1 » Wed Feb 01, 2023 8:14 am
    everything is working normally.you can update
  • burakaltun1
    by burakaltun1 » Wed Feb 01, 2023 8:15 am
    There is only one thing left to fix. When going full screen, the mouse cursor appears on the screen.
