Mad Mapper Output to Syphon
    pele2010
    Re: Mad Mapper Output to Syphon
    by pele2010 » Sun Aug 28, 2016 1:12 am
    Hey ,
    I checked the syphon output of the Beta Version of MM and can´t find it anymore ?
    the same is with mad doubler, no madmapper
    does it have to be activated?
    thanks pele
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    pele2010
    by pele2010 » Tue Aug 30, 2016 6:36 pm
    Ok,
    found it !
     > Its under the preferences !
    > Misc
    > activate Syphon Output
    great , thanks
    Peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • robflate
    by robflate » Sun Nov 19, 2017 5:18 pm
    This used to be available in the prefs but now I can't find it? Has it been removed? How do I output to syphon now? Thanks.
    Edit: This post helped me find the Syphon Output setting in MadMapper. viewtopic.php?f=21&t=9942
    by mad-matt » Fri Nov 24, 2017 3:56 pm
    No. In MadMapper 3 it's better, you can start Syphon output for any projector individually, even if there's no active view for it (no fullscreen nor preview). You can have check the "Publish to Syphon" button in the projector settings.
Users browsing this forum: No registered users and 63 guests
