So I went back and checked your fix and you've missed a line in the init script. Plus the original 1.0 module is in the public section, which will be confusing...It's fixed there is a new version (1.1) in the online library.I found the 1st issue :
The module 'syphon input' does not choose the correct media!
I new t-shirt for my collection!
Lol, didn't notice this and I just found the same issue in the syphon module, so I made a fix and uploaded it to the library, then found your post:-
Public Library > Syphon Input for M8-HD (layer)
I will try to update the Micromodul8 too soon. You have given me lots of work - thanks ; 0
noticed some weirdness in the midi mapping when on position- Notice the two green boxes next to the layer speed + the master BG color shouldn't be mappable in position or layerset + position.
Loving all the new features, especially the locking and added media sets. I'm excited to dive deeper!
Hardware Overview:
Model Name: MacBook Pro
Model Identifier: MacBookPro11,3
Processor Name: Intel Core i7
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Memory: 16 GB
Boot ROM Version: MBP112.0138.B16
SMC Version (system): 2.19f3
I have a frame rate issue.
Play back isn't as smooth in full screen mode
When I switch to full screen the frame rate drops a great deal.
desktop mode - 90-100 fps
fullscreen mode 26-28 fps
i7 macbook pro 2014 16gb 512 pcie ssd el cap modul8 HD beta1 conected to a samsung hdmi tv
playing one 1080/30 mjpeg loop
edit - this is happening only with this particular M8 set? dont know why. here is the image file used; -----
Next Issue: Blending Modes Glitch?
Premul, Scr, and Exc mode causing unusual results!
I noticed this when loading up a set which works fine in 2.9
Using .PNG with alpha channel
Including example shots ( how I would love a way to import vector shapes directly, without converting them to bitmaps ; - )
The module library is not open. When trying to access it to the program of work is to restart the computer to open the Modul8 again
I MAC
2,7 GHz intel core i5
8GB
MAC hd
Tests performed on Mac Pro 2011 version 10.11.6, 2 GHz intel core I7 8GB, the modules worked perfectly
Modul8 v3.0 hd BETA freezes immediately when I select any module from the modules menu. Even if no media has been imported to the project yet.
Macbook Pro Retina, Mid 2012
16 GB Ram
OSX 10.8.5
