Matrox TH2G with Edirol V4.. is it possible?
  • mono79
    by mono79 » Thu Apr 23, 2009 1:32 pm
    Hi spxl,
    Thanks for that idea!
    we intend to have a 10 by 3 meters Canvas to create live compositions on. (we like to have more space horizontally)
    That "mix-2-go" setup, as you call it is exactly what I was thinking of. I'm not sure if the hook-up of a second computer via ethernet will work but so far that might be the best option to work with. But honestly, I'm still a little concerned about a system crash on my MBPro (especially running M8, LiveCam and DVD?!
    Does anyone have a solution sending video over ethernet or connectiong two MBPro's and using one of them as a "Master" and the other one as "slave" like you can use ReWire on audio side? Setting up like that you would be able to send the video out from machine #1 via ethernet to machin #2 and use the videostream as an input in M8?
    Would be really great!
    @Deepvisual:
    I was thinking of using an HD projector to have more resolution that I could crop on top and bottom to have that kind of widescreen, because the 3 x V4 Setup isn't affordable at the moment :)
Users browsing this forum: Google [Bot] and 38 guests
