david wrote:Hi all,
Modul8 2.5/2.6 is using QuickTime framework for doing video capture.
So if you recording/grabbing device is supported by QuickTime (test with the record function of QuickTime Player pro), it should work with Modul8.
For USB Camera, they should be compliant with UVC (Universal Video Class)
For firewire, cameras using IIDC or DFG/1394 are supported. DV cameras are supported, but QuickTime is able to capture only one DV stream at a time.
For other devices, they should have a VDIG or other QuickTime compatible driver (which is the case for blackmagic products but not for Elgato low-end products).
Concerning AVCHD, I think most AVCHD cameras are not capable of sending a real-time video stream to the host computer. They are storing their data locally and then you could get the encoded movie from your Mac (QuickTime has no native support for AVCHD, so you need to transcode to a QT supported format).
Last, HD support in Modul8 2.5.8 means that we support resolution higher than PAL/NTSC/VGA/XVGA/...; Previous versions were limited to 1024x768 so people with blackmagic cards were not able to get HD videos.
HDV should be supported. If you manage to grab an HDV stream into QuickTime player and not in Modul8, please contact support[at]garagecube.com.
I hope this clarify the current situation about grabbing.
David
PS: 2.6 supports upto 4 simultaneous video grab.
Users browsing this forum: No registered users and 79 guests
