R-e-R wrote:i have the pinnacle dazzle dvc 130...installed video glide...but in m8 2.6 capture preferances video glide is in the list, but greyed out...does this mean my device is not compliant with with videoglide and or modul8?
should i just get the easycap?
thanks this thread was a great read and info source.
update:
i found a device that works...startech svid2usb2..with video glide...i had that device for my pc lappy and got the dazzle for the mac...but with video glide the startech one works on both...bye to the dazzle:O)
the grabee software for the startech unit that comes withit is shite tho and i need to find something to use on pc for capturing my av sets, any ideas? is there video glide for pc maybe?
i may just get a blackmagic card for capturing hq av sets i guess, but really wanna do a demo now:O(
R-e-R wrote:http://www.motu.com/video-products/hdx-sdi/
david wrote:Hello R-e-R,R-e-R wrote:http://www.motu.com/video-products/hdx-sdi/
from the Motu website, it seems to have only "drivers" for Final Cut Pro.
Modul8 uses QuickTime vdig/SequenceGrabber API to get video from capture devices.
So I would say that the MOTU HDX-SDI will not work with Modul8.
Regards.
David.
PS: I asked MOTU about the technical details. I will keep you posted.
lotech wrote:Yeah I just picked up a DC60+ for $US29, it arrived I plugged it, videoglide installed works perfectly below 1sec latency. The is some latency still there but much better than any DV input.
Once thing have still to deal with though is the interlacing, the freeframe plugin works but seems to dip the luminance and soften the image. Is there another option people use?
Users browsing this forum: Baidu [Spider] and 47 guests
