Keyboard or Midi control of Preset selection?
    pele2010
    Re: Keyboard or Midi control of Preset selection?
    by pele2010 » Fri Apr 26, 2013 2:08 pm
    1. Target "preset"
    2. Property "preset" (but i dont get a menu to select the preset)
    so i selected the preset
    3. i selected "learn" and then pressed the button on the midiinterface
    returnis a not
    then i did this with a second selected preset.
    But with pushing the buttons nothing happens.
    Do i have to change "channels" for the buttons ?
    Any help ?
    thanxs Pele
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    aktion
    by aktion » Fri Apr 26, 2013 2:17 pm
    Hi The presets cannot be indivually mapped YET in madmapper please read this post from the beginning to get a sense of how they work.
    1. Target "preset"
    returnis a not
    Any help ?
    thanxs Pele
    AKTION STUDIO
    pele2010
    by pele2010 » Fri Apr 26, 2013 3:42 pm
    Ups, missed the Tabs!
    but with midi CC i will need to set up a core midi interface, or ?
    thanxs
    #eachfilm01
    #pele2010
    www.eachfilm.de
    aktion
    by aktion » Tue May 07, 2013 4:17 pm
    thanxs
    i am not sure what you mean.. i never did anything more than whats mentioned in the post.
    AKTION STUDIO
    by franz » Wed May 15, 2013 7:14 pm
    setup an IAC bus and you're good to go (not necessary but quite usefull)
    luminusvj
    by luminusvj » Fri Oct 25, 2013 8:02 pm
    hello friends, I managed to figure out how this software blibioteca my Midi Controller Akai - APC 20, so that it is simpler to mapping the controls midi mapping in medmapper
    follow the link below hope it helps.
    http://translate.googleusercontent.com/ ... rMpR4ZAc5g
    by franz » Wed Nov 20, 2013 4:49 pm
    foir midi/keyboard control, please try madmapper 1.6 ,
    these features are not bundled in
  • te-c
    by te-c » Sun Nov 24, 2013 1:21 pm
    I've tried the new beta with midi-functionality but if I close a document and open a new one the midi-control-list is empty.
    How can I save the midi-controls for the programm and not only for one project-file?
  • jeanpoole
    Can't get midi functionality working..
    by jeanpoole » Thu Feb 06, 2014 8:41 am
    Hello -
    I'm having trouble getting the MIDI functionality to work -
    have tried typing the following into terminal:
    defaults write com.garagecube.madmapper midirouterEnabled 1
    .. but upon restart, no edit midi menu is shown.
    (for various other reasons, I'm on mavericks. Could this be some permissions related problem?)
    And - I can't use 1.6 - as it doesn't show any syphon input for me...
    Any tips / assistance greatly appreciated...
    cheers!
  • jeanpoole
    by jeanpoole » Thu Feb 06, 2014 9:20 am
    Update: I managed to get syphon going in 1.6 after all... tried quartz syphon and that worked... then retried VDMX and that worked too! I think maybe I'd been launching VDMX first, and madmapper 2nd before... perhaps MM has to be launched first to recognise other syphon inputs?
    Anyways... MIDI is working now... albeit on a 1.6 beta on the un-recommended mavericks... we'll see how it sails...
    danke!
Users browsing this forum: No registered users and 66 guests
