Locked 51 posts
Modul8 v3.0 hd BETA
  • Videometry
    Re: Modul8 v3.0 hd BETA
    by Videometry » Tue Aug 30, 2016 8:09 am
    Still getting some strangeness in the midi mapping on v3...
    I'm just creating a layer, hitting edit midi map, then switching between position and layerset + position modes. The BG Color G + B stay mappable green while red does not (they should all be off?).
    If i duplicate the blank layer a few times and then re-enter the mapping mode in position or layerset modes those ghost boxes re-appear... Are you able to reproduce? Let me know if you need any info on my system-
    weird mapping parameters
    Screen Shot 2016-08-30 at 2.00.20 AM.png (244.64 KiB) Viewed 15608 times
    pele2010
    by pele2010 » Sun Sep 04, 2016 5:26 pm
    ( how I would love a way to import vector shapes directly, without converting them to bitmaps ; - )[/quote]
    me too!
    it saves so much time!
    thanks peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • sir.phit
    by sir.phit » Sun Sep 11, 2016 3:11 am
    crashes on open, this is the apple report it gives me.
    Process: launchd [3119]
    Path: /Applications/Modul8/Modul8.app/Contents/MacOS/Modul8
    Identifier: com.GarageCUBE.modul8-30
    Version: ??? (???)
    Code Type: X86 (Native)
    Parent Process: launchd [128]
    Date/Time: 2016-09-09 23:26:04.225 -0700
    OS Version: Mac OS X 10.7.5 (11G63)
    Report Version: 9
    Interval Since Last Report: 352140 sec
    Crashes Since Last Report: 4
    Per-App Crashes Since Last Report: 4
    Anonymous UUID: 5EBEFDBE-4FD8-4142-BD5E-F9891BDBAA4B
    Crashed Thread: Unknown
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x000000008fe01030
    Backtrace not available
    Unknown thread crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0x00000000 ecx: 0x00000000 edx: 0x00000000
    edi: 0x00000000 esi: 0x00000000 ebp: 0x00000000 esp: 0x00000000
    ss: 0x00000023 efl: 0x00010202 eip: 0x8fe01030 cs: 0x0000001b
    ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x00000000
    cr2: 0x8fe01030
    Logical CPU: 4
    Binary images description not available
    External Modification Summary:
    Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
    Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    Calls made by all processes on this machine:
    task_for_pid: 4089
    thread_create: 1
    thread_set_state: 0
    Model: MacPro3,1, BootROM MP31.006C.B05, 8 processors, Quad-Core Intel Xeon, 2.8 GHz, 4 GB, SMC 1.25f4
    Graphics: ATI Radeon HD 5870, ATI Radeon HD 5870, PCIe, 1024 MB
    Memory Module: DIMM Riser B/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
    Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 800 MHz, 0x0000, 0x000000463732353642363145353830304600
    AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x87), Atheros 5416: 2.1.14.9
    Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
    Network Service: Ethernet 2, Ethernet, en1
    PCI Card: ATI Radeon HD 5870, sppci_displaycontroller, Slot-1
    PCI Card: ATI Radeon HD 5870, ATY,LangurParent, Slot-1
    Serial ATA Device: WDC WD10EAVS-00D7B1, 1 TB
    Serial ATA Device: Samsung SSD 850 EVO 250GB, 250.06 GB
    Serial ATA Device: SanDisk SDSSDHII480G, 480.1 GB
    Parallel ATA Device: PIONEER DVD-RW DVR-112D
    USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd200000 / 2
    USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfd220000 / 3
    USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8206, 0x5d200000 / 3
    USB Device: Dynex 5-Button Wired Optical Mouse, 0x0461 (Primax Electronics), 0x4d42, 0x5d100000 / 2
    by boris » Wed Sep 28, 2016 7:38 pm
    Good news, I found the way to reproduce it and it's fixed now for the next upcoming Beta (release planned tomorrow).
    You definitely win a t-shirt :-)
    Boris.
    Videometry wrote:Still getting some strangeness in the midi mapping on v3...
    by Pierre Guilluy » Thu Sep 29, 2016 2:08 pm
    @VJFranzK
    The problem you experience with your alpha PNG seems to be due the its odd number of lines (1920x1893).
    I could reproduce the same problem in MadMapper and other concurrent softwares as well.
    From what I can see, the image is fully-white with a alpha mask that defines the rounded shape.
    It seems like such an image confuses the OpenGL drivers which produces a texture with a correct Alpha channel, but messed up RGB channels.
    Resizing the image to an even number of lines fixes the problem.
    Pierre
    Screen Shot 2016-09-29 at 13.27.28.png (223.92 KiB) Viewed 15462 times
    by Pierre Guilluy » Thu Sep 29, 2016 6:11 pm
    @VJFranzK again
    After further testing, I'm not sure the problem comes from OpenGL rendering, because I've been able to produce a transparent PNG with the exact same size that doesn't produce the same issue.
    What software did you use to export your image?
Locked 51 posts
