How To Output Ethernet
  • BenPower
    by BenPower » Sat Oct 07, 2017 3:59 pm
    I have bought some LED fixtures from SGM Lights http://sgmlight.com/standard/ld-5/c-23/p-152
    I want to use Madmapper to run them. I need to output ethernet to the lights with POE so was thinking that I could buy this USB DMX interface https://www.enttec.com/uk/products/cont ... n-dmx-usb/ and then bring the DMX in to this https://www.enttec.com/uk/products/cont ... t-mk2-poe/ to power and the lights with the ethernet output.
    Has anyone used this same method? Is there a simpler way to do it? Am I just being a bit thick and it's definitely more straight forward than I am making out?
    Any help would be greatly appreciated.
    I initially wanted to use Madrix but have changed my mind as I think Madmapper can be more utilitarian for the various things I am doing in the venue I work for and I've used it before for projections.
    Thanks.
    Ben.
    Re: How To Output Ethernet
    by mad-matt » Sun Oct 08, 2017 10:16 pm
    I don't understand, you want to output DMX from the computer with a USB-DMX device and then convert the DMX to ethernet ? MadMapper can send ArtNet or SACN (dmx over network).
  • BenPower
    by BenPower » Mon Oct 09, 2017 2:15 pm
    So if I get something to send power over Ethernet this will work straight from my laptop ethernet?
    by mad-matt » Mon Oct 09, 2017 5:44 pm
    If you want to have ArtNet yes, but it looks like your device needs a physical DMX signal, not ethernet. So you could use a USB-DMX box (directly connected to the computer) or send ArtNet (ethernet dmx) from the computer and use an Enttec ODE to convert ArtNet to DMX.
  • Oaktown
    by Oaktown » Sun Dec 17, 2017 7:29 pm
    Why don't you check out the connection diagram supplied by SGM? It has all the information you need to set this up!
    https://www.dropbox.com/s/qp5k0h69ku6d4 ... 3.png?dl=0
