3D Shape Rotation
  • Partyman
    3D Shape Rotation
    by Partyman » Sun Oct 08, 2017 12:36 am
    is it possible to make 3D shapes rotate? I know how to do it in set up and move around the angles but is there a way to have the cube rotate on main output?
    Re: 3D Shape Rotation
    by mad-matt » Sun Oct 08, 2017 10:12 pm
    You can put a control on "/surfaces/3D surface/3d_rot_y"
    You can use a MIDI or OSC sequencer to send a value to this control or if you want a continuous rotation, you can use MadMapper BPM Global channels:
    Open Controls dialog (menu Controls / Controls List), press the "Other" tab on top, the the "+" button on the left and in the menu browse for /surfaces/3D surface/3d_rot_y, in the control settings choose device "BPM" and channel "bpmOffset-8" (that's a channel that will go from 0 to 100% each 8 beats)
