function publish to spout
  • WillyBsm
    by WillyBsm » Sun Oct 15, 2017 5:21 am
    Hi
    Newbie on Madmapper I did not find any info on the function " Publish to Spout " in section projector.
    What is the use of this function?
    thank you very much
    Re: function publish to spout
    by mad-matt » Mon Oct 23, 2017 9:56 pm
    In the projectors tab, select your projector, below the projectors list you have its properties, there is a button "Publish to Spout" there.
  • WillyBsm
    by WillyBsm » Tue Oct 24, 2017 9:20 pm
    thanks for your help.
    I tried to use it but clicking the button, madmapper closes instantly without further warning.
    I was thinking about a bug or maybe I'm using the demo version.
    thanks again
    by mad-matt » Thu Nov 02, 2017 4:09 pm
    It's not supposed to crash in any way... Have you tried updating your graphics drivers ?
    Can you try to install Spout SDK (http://spout.zeal.co/download-spout/)
    In folder Program Files (x86)\Spout2\SPOUTDXMODE
    Start the executable and set it to DirectX 9. Someone solved a problem this way, but it was not crashing !
    I'd like to understand your crash...
  • davidtsai
    by davidtsai » Fri Oct 11, 2019 2:06 pm
    thanks again
    I also have the same problem after clicking the button, madmapper closes instantly without further warning, my video card is Nvidia Quadro K420 , how do I do ?it spout to madmapper .
    by mad-matt » Mon Oct 21, 2019 4:35 pm
    Are you graphics drivers up to date ?
