Rebooting or starting a MiniMad with the onboard buttons
  • b.demaertelaere
    by b.demaertelaere » Fri Dec 15, 2017 11:56 am
    I know you can shutdown a MiniMad by pressing the RED and BLUE button.
    But is there a way to have the MiniMad reboot or boot by pressing a button or button combination, without the need of a USB keyboard or un/plugging the power?
    Re: Rebooting or starting a MiniMad with the onboard buttons
    by Pierre Guilluy » Tue Dec 19, 2017 2:58 pm
    You can reboot the miniMAD by holding the three colored buttons at the same time.
  • AgentD
    by AgentD » Thu Aug 08, 2019 9:32 am
    Hello, I just tried to reboot the MiniMad by pressing three buttons (red/blue/yellow) at the same time but nothing happens. I also tried with Red/Blue combination as well. Am I missing anything? Is there any other way to reboot besides from unplugging the power? Please let me know. Thanks!
    by MADben » Thu Aug 08, 2019 3:31 pm
    hi,
    make sure you're running the latest version of MadMapper,
    then you should make sure that your miniMAD is "updated" - to do so you can restore your miniMad's sd card:
    - download first the image disk on the madMapper yourspace page : https://madmapper.com/yourspace
    - download the Etcher app as well : https://www.balena.io/etcher/ (the link is also available on the yourspace page)
    - then all the steps are explained in the page 13 of the miniMad manual : https://madmapper.com/wp-content/upload ... RGUIDE.pdf
    The image disk is huge - if the downloaded file doesn't work it's mostly due to a download fail at some point, you'll have to download the image disk again.
    let me know
  • AgentD
    by AgentD » Thu Aug 08, 2019 7:51 pm
    hi,
    let me know
    Thank you for your answer! I am downloading the disk image now and will try it once it's complete. Thanks again!
