Can Madmapper be controlled through MIDI?
  • kozman007
    by kozman007 » Wed Jan 10, 2018 10:15 pm
    From what I see Madmapper will do what I need. 34 metres of RGBW Pixel strips. On the forum it seems there is a way to control that but you have to split the RGB from the W. Is that correct? I have a launchpad pro MIDI controller. Can you control the lights through this?
    Re: Can Madmapper be controlled through MIDI?
    by mad-matt » Tue Jan 16, 2018 12:13 pm
    Digital RGBW strips can be controlled by MM without splitting RGB & W, just using the RGBW pixel type.
    To control with MIDI, choose menu Controls / Edit MIDI Controls, then press your fixture "luminosity" slider, move a MIDI knob or press a MIDI key, and it will associate this MIDI knob/key to this fixture luminosity. If you have many fixtures in a group, you can map your MIDI knob to the group luminosity to have a single assignment for all or part of your LED bars/strips.
