Hardware Sanity Check (Datapath + 1920x1200 x 3)
  • dimitry
    by dimitry » Tue Jan 23, 2018 4:02 pm
    I'm new to projection tech and trying to verify if I'm doing these calculations correctly. We have a need for 3 projector setup, each with 1920x1200 resolution, making the final screen 5760x1200 @ 30fps. That's 1920*1200*30 = 69 MP/s. Datapath FX4 spec says each output can be up to 165 MP/s. Seems like we're well within that. Am I understanding this correctly?
    Would either FX4 or the X4 version be able to drive this experience w/o a problem?
    We're hoping to use a Mac Pro (6,1) here. Is the command line interface for OSX by Datapath fairly straightforward as far as configuration?
    Thank you very much!
    Re: Hardware Sanity Check (Datapath + 1920x1200 x 3)
    by mad-matt » Tue Jan 23, 2018 8:17 pm
    I have no experience with Datapath products (it has good reputation through). When I do multi-output on a Mac Pro, I connect 6 screens with active MiniDP->HDMI adapters - about 20$ each and we can have 60 FPS on 6x Full HD with many HD movies playing. Use latest MadMapper for best performances.
  • dimitry
    by dimitry » Tue Jan 23, 2018 8:34 pm
    Thank you Matt! Very helpful. We were originally planning to go straight to Mac Pro, but wasn't super sure it could handle 3x projectors @ 1920x1200. Have you tried running multiple projectors @ 1920x1200 resolution before? Thank you
    by mad-matt » Wed Jan 24, 2018 3:16 pm
    Wr did 6x 1920x1080, so there will be no problem. Version 3.2.2 is even better than previous because we adjusted the OpenGL engine to handle specific apple AMD driver things. I can create 20 fullHD preview windows and still have 60FPS with a few materials (even if it's not displayed on a projector the graphics card renders it), so no problem in your case.
