can't download and BACF?
  • studioc
    by studioc » Tue Jul 25, 2006 4:59 am
    I can't seem to download user modules from the online library in the 2.5 beta. Also, is there a BACF module in the works for 2.5? That module is indispensible to me. For this reason I generally use the 2.X version. Any information on this would be greatly appreciated. - Jim C.
    The Revolution must be televised!
  • jm302
    by jm302 » Tue Jul 25, 2006 7:28 am
    Greetings,
    I think the library is disabled for the beta but you can copy and paste your modules folder from 2.x into the beta folder (not all modules work because of changes in the python keywords).
    Cheers,
    Justin
    http://www.302acid.com
    Re: can't download and BACF?
    by boris » Fri Aug 25, 2006 5:41 am
    The M(master)-BPM Router replace now the BACF module.
    (we will add a default preferences).
    But you can also use the BACF from the v2 if you want, is it compatible.
    studioc wrote:I can't seem to download user modules from the online library in the 2.5 beta. Also, is there a BACF module in the works for 2.5? That module is indispensible to me. For this reason I generally use the 2.X version. Any information on this would be greatly appreciated. - Jim C.
