New to MM
  • Mazen88
    New to MM
    by Mazen88 » Fri Feb 09, 2018 10:30 pm
    Hi guys , I am new to this software and I have a very basic question which is, to start mapping should I have a picture of the object that I want to map on. another quick question is that what are the recommended projectors that work fine on MM version 3.2.2 the demo version cause I have tried NEBULA projector and i had a rough time to project.
    Thanks !
    Re: New to MM
    by franz » Mon Feb 12, 2018 8:09 pm
    did you have a look at the tutorials already ?
    Some might provide answers.
    https://www.youtube.com/channel/UCC9p0f ... 3n9fXFjpgg
    You don't need a picture of your object, you can use madmapper's built-in materials
    to project generative content on your object.
    As for projector,
    I'd recommend having a look at http://www.projectorcentral.com/
    and select a projector according to your budget.
