OSC triggering a Jpeg
  • AnnaFB
    by AnnaFB » Mon Feb 12, 2018 5:36 pm
    Hey,
    I am using a RPi to send OSC signals to madmapper, triggering animations.
    I also need to be able to send an OSC signal to tell madmapper to show/hide an image.
    Is this at all possible?
    Best,
    Anna
  • waynabrossas
    Re: OSC triggering a Jpeg
    by waynabrossas » Tue Feb 13, 2018 12:41 pm
    Yes, you have to create a quad, with the image as input.
    And then you have to go in commands / edit osc controls, click on the square that shows / hide the quad to assign it to your osc command
    Capture d’écran 2018-02-13 à 11.38.06.png (57.74 KiB) Viewed 3043 times
