GIFs in folders don't play
  • OlofWe
    by OlofWe » Tue Feb 13, 2018 1:17 pm
    GIF support works fine one by one, but not if they're in a folder.
    When I add a folder of GIFs to the Media Set it just shows the first frame of each one – like the old versions used to do.
  • OlofWe
    Re: GIFs in folders don't play
    by OlofWe » Tue Feb 13, 2018 2:53 pm
    Also, I just noticed it's only playing two of the four frames of each of my GIFs when I drop them in normally.
    Here are the ones I made for testing.
  • Lupin
    by Lupin » Mon Apr 09, 2018 2:29 pm
    when you load a folder as media each file is a single frame. an animated gif is considered as movie this is why it's not played
  • OlofWe
    by OlofWe » Sat Apr 14, 2018 6:40 pm
    when you load a folder as media (…) an animated gif is considered as movie
    Sure, but is this correct? If GIF:s are now supported in the new version, the expected behaviour would be that they also be recognised in a folder, right?
    by Pierre Guilluy » Mon Apr 16, 2018 10:45 am
    It makes sense, but animated GIFs are played back as video files in version 3, whereas folder player only support static images, at least for now.
