Madmapper/Arduino Mega
  • denmark219
    by denmark219 » Wed Feb 28, 2018 8:40 pm
    All, I made a video of my situation. I have the LED's wired through an Arduino and I followed the tutorial for the FastLED serial connection. As you can see in the video, madmapper is talking to the arduino, but the LED's aren't coming on. The LED test works fine, but I just get nothing when trying to drive them from madmapper.
    Here is a video to the setup:
    https://youtu.be/OWqvzxWOG1A
    Thanks for any help you can give me!!
  • denmark219
    Re: Madmapper/Arduino Mega
    by denmark219 » Mon Mar 05, 2018 5:24 pm
    Just an update... I gave up on the mega. I did use a Teensy and wasn't able to get any LED's to light up. I ended up commenting out these lines from the FastLED-serial-only-single-line.ino and it fixed it:
    Code: Select all
    //while (!Serial) { // wait for serial port to connect. Needed for Leonardo only //}
    by mad-matt » Tue Mar 20, 2018 1:20 am
    Thanks for your feedback. I'll update the ZIP file with this line removed.
    Cheers !
