NOT audio input on Mad Maper 3.3 windows
  • chindo
    by chindo » Thu Apr 19, 2018 8:41 pm
    Only internal soundcard is detected and no receiving any signal
    Re: NOT audio input on Mad Maper 3.3 windows
    by mad-matt » Fri Apr 20, 2018 9:17 am
    MadMapper only detects default audio input selected in the system. If you want to have all audio inputs running you can set an hidden setting:
    on macOS: in Terminal: defaults write com.garagecube.MadMapper enableAllAudioInputs 1
    on Windows: in Cmd.exe: REG ADD HKCU\SOFTWARE\Garagecube\MadMapper /f /v enableAllAudioInputs /t REG_SZ /d 1
    If you don't get a signal, check in master tab the "audio in level", and check in your system that you get a signal.
