Mapmapper > MiniMad export very slow
  • Chicorea
    by Chicorea » Fri Apr 20, 2018 7:54 am
    I am trying to convert 2 videos .mp4 (400Mb and 250Mb) which i just modify the quad surface for the videoprojector. Everything went well but when i am trying to export to the SD Minimad card the progress bar is very slow and seems blocked to 12%.
    Perhaps it is a codec problem but i don't think because i try many things about that.
    Someone have an idea of the cause of the problem?
    Thanks in advance,
    Re: Mapmapper > MiniMad export very slow
    by Pierre Guilluy » Fri Apr 20, 2018 10:00 am
    Do you work on Mac, Windows?
    How long did you wait?
    With some codecs it happens the transcoding session seems to be frozen, and suddenly jumps to 100%.
    You can also send me a link to your file in a PM, so I can try reproducing the problem.
