MIDI priority
  • Regeller
    MIDI priority
    by Regeller » Sat Apr 21, 2018 4:51 pm
    I have a problem concerning MIDI. My setup is: Win10, Magic Visuals->Spout->MadMapper. I have three MIDI-devices attached to control Magic. One KORG nanoKey, one Novation LaunchControl XL through USB and another LaunchControl through an extrenal MIDI-host going into a Fireface which is connected to the PC. This is because only one LaunchControl through USB at a time is recognized by the system.
    Now it happens that I loose control over the USB-connected LaunchControl while performing. And I have strong indication that MadMapper is taking over control of this device. Is there anything to do to prevent MadMapper to do so? I would not need MIDI at all for MadMapper. I only use it for controlling Magic. So a simple switch "Ignore MIDI" would be good for me.
    Any advice ist welcome.
    Thanks
    Reinhard
    Re: MIDI priority
    by mad-matt » Mon Apr 23, 2018 10:58 am
    You can disable all MIDI input devices in MadMapper. Start MadMapper without any other MIDI application running. In MM Preferences / MIDI you will see all connected devices, uncheck them all so MadMapper doesn't open it. That should fix.
