Make Line Material audioreactive to 90 layers?
  • Chris Noelle
    by Chris Noelle » Tue Apr 24, 2018 12:31 pm
    I have an installation where i have 90 audio-snippets and 90 horizontal aligned quads on a 16:9 projection.
    Is it possible to get the LINE Material independenat audioreactive to each of the 90 boxes so the running lines can react different in each quad?
    The final loop should be played out to miniMAD, where you won´t hear the sound, but you will see the projection.
    Any solution appreciated!
    Re: Make Line Material audioreactive to 90 layers?
    by mad-matt » Tue Apr 24, 2018 1:13 pm
    Select the "line material" and press Cmd+D / Ctrl+D, it will duplicate the media, then you can change parameters and assign this new media to another surface.
    miniMad will not play the materials for performance reasons. To do what you want, you'll have to record MadMapper output as a video (using application "Syphon Recorder"), then using this video on a quad in MM to export to miniMad.
