Making Curve shape
  • balamsoto
    Making Curve shape
    by balamsoto » Thu Apr 26, 2018 3:59 pm
    is it possible to mask curve shapes?
    like a circle or waves shapes
  • Teunkneus
    Re: Making Curve shape
    by Teunkneus » Mon Apr 30, 2018 9:33 am
    As a quad or a mask?
    And both yes! you can create a circle just like a quad and manipulate (less options then quad)
    And you can use a quad and bezier the shit out of it.
    But if you explain what you want to create I can be a bit more specific.
  • balamsoto
    by balamsoto » Thu May 03, 2018 7:47 pm
    thanks
    how / where do you enable the bezier - I only get dots and lines
    can find a way to bezier the lines
    I want to export the mask to the minimad
    curve shapes like wasves
    is it possible
    by mad-matt » Mon May 07, 2018 4:02 pm
    There is no bezier on masks at the moment
