Minimap - can´t get it running
  • Chris Noelle
    by Chris Noelle » Mon May 07, 2018 1:33 pm
    Today I wanted to use my Minimap for the first time. So I exported a simple clip from Madmapper and during the export the popup tol me that the latest version of MiniMap is needed. So I clicked ok for installing the update and then finished the export to the Mini-SD Card with success. Then I stucked the SD into the MiniMap and it booted for a while. After waiting for about 6 minutes, the codelines were finished but the exported clip doesn´t start.
    How can I get it running?
    Thanks for your help.
    Best wishes
    Chris
  • Chris Noelle
    Re: Minimap - can´t get it running
    by Chris Noelle » Mon May 07, 2018 5:12 pm
    Solved, after the 4th export it was up and running, no idea why it didn´t work before, but for now it´s perfect!
