MadMapper 3.5 beta released
    by franz » Wed May 16, 2018 4:48 pm
    Hi, we're happy to publicly release MadMapper version 3.5 beta.
    This version features a completely re-designed cue system,
    aimed at replacing presets.
    Download the beta from www.madmapper.com/yourspace
    There's a PDF available on yourspace with a brief documentation.
    Simple video tutorial here:
    https://youtu.be/joYnwj1PcmA
    Enjoy, let us know if you find any bugs, let us know your comments.
    The MAD Team
  • te-c
    Re: MadMapper 3.5 beta released
    by te-c » Wed May 16, 2018 8:10 pm
    Really great feature!!! Thanks for that!
    I have a wish in the cue editor it would be nice if the order in the editing section for the surface would be the same as in typical section on the left side of the program. So the colors should be the same order etc.
    Blend Mode
    FX Type
    Color
    Red
    Green
    Blue
    etc.
    It would be faster and clearer as now.
    by franz » Thu May 17, 2018 3:25 pm
    good point !
  • balamsoto
    by balamsoto » Thu May 17, 2018 8:00 pm
    looks great!!!!!!
    is this update free for current 3.3xxx version holders?
    by mad-matt » Thu May 17, 2018 8:55 pm
    Yes !
  • descalxo
    by descalxo » Sun May 20, 2018 12:41 am
    Hi! I found 2 issues with the new beta release. I opened a project and when I tried to resize some quads the position controllers didn't appear. Also lost a few button configuration with from my midi controller (AKAI MIDIMIX) guess is because the new added features.
    by mad-matt » Mon May 21, 2018 8:51 pm
    Which controllers ? The "Output Pos" x/y spinbox that appears in the top toolbar when you select a handle ?
    Yes, some controls and all presets will be lost when opening a project made with a previous release
  • descalxo
    by descalxo » Mon May 21, 2018 11:01 pm
    I make a video to explain better what is going on. You can watch it here https://youtu.be/UMUE3unAUe8
    by mad-matt » Wed May 23, 2018 11:43 pm
    I can reproduce it and will fix it for beta 2. Thanks for the video !
  • descalxo
    by descalxo » Sun May 27, 2018 12:11 am
    You're welcome!
  • al_baum
    by al_baum » Wed May 30, 2018 8:14 pm
    Hi, I downloaded Madmapper 3.5beta from my space.
    On the site, it says that the beta will expire on June 14th, but when I try to open the app, i get a message saying that it expired 0 days ago. What should I do ?
    by mad-matt » Thu May 31, 2018 9:56 am
    Indeed the version expired. We're updating it right now. Check in a few minutes
    by mad-matt » Thu May 31, 2018 1:11 pm
    Fixed
    by mad-matt » Fri Jun 08, 2018 8:49 pm
    MadMapper 3.5.0 Beta 2 is there and adds "Scenes" (special cues that contain all document state, a bit like Presets but with edition facilities, ie: updating the geometry of a quad in all scenes in one click). Check it out: http://www.madmapper.com/yourspace
  • bzabiz
    by bzabiz » Thu Jun 21, 2018 2:55 pm
    Any idea when the stable version would be released?
    I'm working on a project and it would make sense to directly set it up with cues.
    I'm just starting with MM, so learning 2 different workflows wouldn't really make sense.
    The event I'll need it for is in August.
    Is it realistic it would be released by then?
