Merging quads
  • jhopgood
    Merging quads
    by jhopgood » Thu May 31, 2018 3:42 pm
    Hi all,
    Quick question - is it possible to select multiple quads and merge the geometry into one common surface. For instance, I've got four separate quads mapped for individual aspects of a wall and would like to just combine them into one mapped surface.
    Re: Merging quads
    by mad-matt » Fri Jun 01, 2018 1:30 pm
    No. But you can press Cmd+G / Ctrl+G to group selected surfaces (or menu Edit / Group selected surfaces). Then you can manipulate all at once, duplicate the group etc. To apply a perspective on a group, press Alt-key and click the handle (group corner) to move.
