Can you control minimad with a makey makey?
  • duttlungafullur
    by duttlungafullur » Tue Jun 05, 2018 2:09 am
    Is it possible to set a key to any parameter control in Madmapper and then control the parameter with the makey makey connected to a miniMad?
    Last edited by duttlungafullur on Thu Jun 07, 2018 12:58 am, edited 1 time in total.
    Re: Can you control minimal with a makey makey?
    by Pierre Guilluy » Tue Jun 05, 2018 11:25 am
    You can use a Makey Makey to control the miniMAD.
    The available controls on the miniMAD are available on the miniMAD user-guide (Yourspace), although the miniMAD doesn't yet support the control mapping assigned in MadMapper.
  • duttlungafullur
    Re: Can you control minimad with a makey makey?
    by duttlungafullur » Thu Jun 07, 2018 1:04 am
    Thanks for your reply! I was planning to use the control mapping but I guess I have to find another solution for that :idea: . It didn't work when I tried but I was avoiding the miniMad's default video playback controls for the keyboard so there would be no conflicts. So I try those and see if it works then.
