thoughts and ideas
  • moonbase
    thoughts and ideas
    by moonbase » Sun Sep 26, 2004 9:13 pm
    Hi-
    just downloaded 1.1 and planning second gig (see first Modul8 experience here " target="_blank">http://www.garagecube.com/forum/viewtopic.php?t=9
    and the following ideas come to mind; if its something already available that I'm missing, sorry, let me know huh- otherwise thoughts for wish list...
    1 - it would be good for the Trace option to be a slider not just on/off if it is technically possible.
    2 - When you duplicate a layer (which is a magical option) how about a numbering/lettering system to differentiatethe child from its parent layer - at the moment they are identical?
    3 - When you add a new empty layer could the default option be' turned off', so that when you link it to an image and forget to engage brain it doesn't pop-up before you want it to!?
    We are using Modul8 with live musicians and have been putting audio line-in through a small Behringer mixer prior to the mac to give a level of control over the audio using the EQ we can pick high/mid/low signals, this gives some little choice over which of the instrument inputs can control the images. Seems to work. Also going to try a gate on the signal to see if we can figure a way of using that for similar.
    Any thoughts anybody?
    any better ideas out there for using the audio-in with multiple instruments?
    And here's a thing - for people using a trackball I recommend disabling the right key - somehow/somewhere if you right click you can lose the pointer irrecoverably behind the Modul8 interface - can't always make it happen but went twice in practice yesterday and you have to quit and start over.
    wonderful8 though!
    moonbase
    Jump to:
    Powered by phpBB 2.0.8 © 2001, 2002 phpBB Group
