MadLight Recorder sync to footage
  • freadZdead
    by freadZdead » Sun Jul 08, 2018 3:46 am
    Hi there,
    Is there currently a way to make MadLight recorder only exactly record all frames from a piece of media? As in eg, put it into a "waiting for signal" state, and then start to play a piece of footage exactly once?
    This is to cater for clips that are designed to seamlessly loop, and to only record exactly one iteration, if that makes sense. So that the MiniMAD ArtNet is basically as efficient and as seamless as it can be.
    Cheers,
    freadZdead (my first post here, yay!)
    Re: MadLight Recorder sync to footage
    by mad-matt » Fri Jul 13, 2018 1:42 pm
    Not at the moment, you can adjust DMX loop in/out points while playing in MadMapper, that should solve your situation
Users browsing this forum: Baidu [Spider] and 30 guests
