Help!
  • Barnabyrudge1
    Help!
    by Barnabyrudge1 » Wed Jul 25, 2018 5:40 pm
    Hi guys please help, I'm creating an environmental project in Kazakhstan and need the ability to control three projectors through one laptop
    -simple stuff one projector showing footage fade to black
    -next projector on then fade to place..then the next.
    the film is a trip from the source of the water the glacier down to the city
    this is projected onto a pyramid using a scrim as a screen
    the projectors will be on cling pointing down. I'll have to mask three shapes two triangles and the last is projecting on water at the base of the pyramid
    I have set up questions then will need a week to get used two simple mapping using three projectors
    I will use a MacBook Pro 15 inch 2017
    processor 2.9 GHz inter core i7
    16 GB
    I will use a large and fast hard drive with plenty of space
    the projectors will have three HDMI cables can anyway list what I need,
    I've been told I may not need a external graphics card. support said I may need Then if you use a macbookpro with thunderbolt 3 ports
    you need either :
    - 3x USB-C Digital AV Multiport Adapter Apple Ref : MJ1K2ZM
    or
    1x Sonnet thunderbold 3 tb3 to displayport https://www.sonnettech.com/product/thun ... apter.html
    + Datapath FX4 + Displayport to HDMI adapters/cable
    can anyone draw me a diagram and help me with what I need? it is for a good cause
    much love Matt :D
