Locked 1 post Page 1 of 1
RC3 released!
    RC3 released!
    by Pierre Guilluy » Tue Jul 31, 2018 5:27 pm
    Hi Modul8 users,
    Here’s the last Release Candidate before the official release.
    We fixed the last bugs we found in previous release-candidate.
    We also improved on modules display, matching version 3 refined design.
    Note: if you’re loading a project made in Modul8 2.x and were using a custom preview aspect-ratio in the preferences, you can get the same working environment by changing the stage aspect-ratio in the new Project Settings window. This way only the width of the stage will be modified (the height will remain untouched at 480) and the application will behave the same way it was in Modul8 2.x.
    Let us know what you think!
    Release Notes:
    Version 3.0 RC3 build 180731_3D2802447B (expiration date September, 15th 2018) - this version requires macOS 10.9.5+
    IMPROVEMENTS
    - Refined modules user-interface
    FIXES
    - Fixed opening projects by double-clicking in the Finder
    - Fixed Mask (global) module
    - Fixed a crash when deleting an image-folder while playing
    Modul8 3.0 is an universal app, meaning it contains both 64 and 32-bit binaries.
    By default it runs in 64-bit mode to take advantage of the full system's memory.
    To put the app in 32-bit mode and benefit from the legacy features, press cmd+I on Modul8.app and check "Open in 32-bit mode" in the information window.
    Please note that 32-bit version of Modul8 doesn't support NDI.
    This Public Beta version is available for any users who own a serial which is compatible with modul8 2.9.xx.
    To download it, use the modul8 yourspace page :
    http://www.modul8.ch/yourspace/
