renaming a group or block of scenes and renumber
  • Christian63
    by Christian63 » Wed Aug 01, 2018 7:15 pm
    how is it possible to rename and renumber a group of scenes :
    for instance I select a group of 7 scenes with various previous numbers and want to rename them in one action for instance "house 1" to "house 7" by order of appearance on the cue line ? (name and number should have to be updated automatically in one single action in reference to the first renamed cue)
    Thank you.
    Christian Lemasson.
  • Christian63
    Re: renaming a group or block of scenes and renumber
    by Christian63 » Wed Aug 01, 2018 11:07 pm
    That would be a nice shortcut to create.
    I have this menue option to manipulate my pictures folders on ACDSee Pro photo software and it is time saving. You just rename the first picture and highlight the group of pictures you selected and click "rename" all the selected pictures will be renamed and assign a new number associated with the chosen name with an ascending increment of +1
    Thank you for your answer.
    Christian.
    by mad-matt » Fri Aug 03, 2018 9:57 am
    There is no shortcut. You have to double click the "TOTO-1" cue and type a "TITI-1", then double click "TOTO-2" and paste "TITI-1" (it will rename it to "TITI-2"), then do the same for all (so 1 double click + a Cmd+V + enter per cue)
  • Christian63
    by Christian63 » Fri Aug 03, 2018 7:10 pm
    Thank you, it works fine. A quicker solution would be a plus.
    Christian.
Users browsing this forum: No registered users and 68 guests
