solution au manque de Ram? le ram disc...
    thease
    by thease » Wed Aug 09, 2006 3:52 pm
    je tombe sur ca par hasard et je me dis...ce serait pas merveilleux d'avoir 700mb de ram en plus pour Modul8!!! pour les boucles qu'on utilise sans cesse...
    reste à essayer
    http://lnx.donelleschi.com/Donelleschi_ ... hp?pag=20_
    What's Ram Disk Creator?
    Ram Disk Creator is a tool to create Ram Disks. This feature was available in Mac OS 9 and below, but since Apple released Mac OS X this capability, unfortunately, disappeared from our Macs. Ram Disk Creator brings them back!
    It's pretty straight forward to figure out whether using a RAM disk is worth it. A ram disk offers the possibility to have the FASTEST DISK your Mac could ever have. Therefore it's the best solution for applications which require frequent disk accesses.
    Moreover Ram Disks are very useful for Powerbooks and iBooks because using a Ram Disk instead of the hard disk means using MUCH less power, therefore dramatically increase battery life. For instance a Powerbook can play 2 hours DivX by placing the movie on a ram disk because there will be only few disk accesses.
    What's a Ram Disk?
    Refers to RAM that has been configured to simulate a disk drive. You can access files on a RAM disk as you would access files on a real disk. RAM disks, however, are approximately a thousand times faster than hard disk drives. They are particularly useful, therefore, for applications that require frequent disk accesses.
    Answer in english or French : as you prefer!
    Répond en français ou en anglais : comme tu préfère
  • Lupin
    by Lupin » Tue Aug 22, 2006 1:17 pm
    J'ai fait l'essai et c'est impressionnant, effectivement le logiciel est tres pratique pour jouer les boucles recurentes qui sont gourmandes en mémoire, en plus pour 15$ on aurait tort de s'en priver
    by boris » Wed Aug 23, 2006 6:07 am
    Sauf que modul8 a déja le mode "ram preload" dans les options de vos media, qui de plus est souvant le mode par défaut, ce qui fait que vous aller plutôt gaspiller de la mémoire.
    Lupin wrote:J'ai fait l'essai et c'est impressionnant, effectivement le logiciel est tres pratique pour jouer les boucles recurentes qui sont gourmandes en mémoire, en plus pour 15$ on aurait tort de s'en priver
