Windows Freezing every 20 min
  • tylewhite
    by tylewhite » Sun Aug 26, 2018 1:32 pm
    Hi All,
    Relatively new mapper here so sorry if this is a repeat question.
    I am getting a freeze - as in media / effects stop playing and the interface becomes non responsive almost exactly every 20mins have tested 6 times
    Computer is
    windows 10 surface book
    8GB Ram, I5, Nvidia GeForce GT 940
    Got my first show in a week - loving it, so just hoping to figure this out. Loving Mad Mapper by the way! Cheers :D Tyler
  • tylewhite
    Re: Windows Freezing every 20 min
    by tylewhite » Sun Aug 26, 2018 1:47 pm
    Ok so it's looking like it could be the GPU - without it activated it's running better. Had a 30min run so far...
  • tylewhite
    by tylewhite » Sun Aug 26, 2018 2:40 pm
    It seems like when the surface book auto switches between the gpu and the integrated graphics it causes mad mapper to freeze - as a solution all i had to do was open up the Nvidia settings and set mad mapper to GPU only. I'm pretty sure it would work if you set it to integrated only.. i think it's the switching that is causing issues. I'll let it run overnight and report back!
    by mad-matt » Tue Aug 28, 2018 3:01 pm
    It's weird that the system changes the GPU while MadMapper is supposed to have active OpenGL contexts running on the nVidia card...
    Check this article: https://recombu.com/mobile/article/how- ... phics-card
    Thanks for your feedback !
