Play 2 different videos in sync at the same time?
  • Perugino
    by Perugino » Fri Sep 07, 2018 11:12 am
    Hi folks,
    Is it possible to use MM in standalone without M8 to play 2 different videos "timing-cued" each other on 2 different quads ? This is a request for a dance show with video files played in very precised moments of the show on 2 different beamers (= 2 different quads), connected on a unique MBPro Touchbar 2017.
    Re: Play 2 different videos in sync at the same time?
    by mad-matt » Tue Sep 11, 2018 11:39 am
    If you use MadMapper 3.5, you can start you medias with a Cue, you can add the "Restart" of both medias in the Cue, please refer to Scenes / Cues documentation (from help menu).
    Another option is to make a single movie with both side by side, and place the input rectangle of each quad on the desired part of the combined movie.
