Projection on Sphere
  • SODABLACK
    by SODABLACK » Tue Sep 18, 2018 1:21 pm
    Does anyone have experience projecting onto a sphere?
    I need to purchase a balloon for a one-sided projection.
    What is the best shape and easiest to mount outdoors - A 16ft weather balloon or a 4m Advertising balloon?
    I haven't tested it, but I assume Madmapper output is simply: Mesh warping - Spherise ?
    Any advice appreciated
  • Robbie the Robot
    Re: Projection on Sphere
    by Robbie the Robot » Wed Sep 19, 2018 10:53 am
    I once projected video onto a large balance ball. I shot the video using a 180 degree circular fisheye lens so when I projected it onto the balance ball it naturally reversed the lend distortion. No mesh warping needed!
  • SODABLACK
    by SODABLACK » Wed Sep 19, 2018 1:07 pm
    yeah that makes sense but I don't have a fisheye for the projector
  • Robbie the Robot
    by Robbie the Robot » Thu Sep 20, 2018 7:17 am
    I used a fisheye lens for the video camera to shoot my footage. The projector had a normal lens. Because the footage is already distorted you don't need a special lens for the projector. The sphere that you project the image on will un-distort the image naturally. But you will, of course, need a fisheye lens for your camera.
