Graphik Card for 8K ?
    pele2010
    by pele2010 » Tue Sep 18, 2018 4:19 pm
    which graphic card should I use on a mac to be able to play 8K video smoothly?
    Any suggestions on this topic?
    Has anybody tested it?
    I checked 4K on an iMac 2017 and the video is not running smoothly.
    And which codec should I use? HAP with 8K or 4K?
    Or H265?
    I tested H265 and I am not sure if the performance of an I7 is enough.
    kind regards Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
    Re: Graphik Card for 8K ?
    by mad-matt » Fri Sep 21, 2018 1:29 pm
    On macOS, HAP is the best. I can play much more than 8k on a MacBook Pro mid-2013. On Windows HAP will be hardware decoded in MadMapper 3.6 (next update).
    Actually HapQ is not hardware decoded so use basic HAP codec. HapQ will be hardware decoded on both macOS & Windows in MadMapper 3.6.
