Minimad OSC over Wifi ?
  • volt'air
    by volt'air » Wed Sep 26, 2018 12:07 pm
    Hi there,
    I'm considering using a Minimad for a future project. For this project, I will need to control with OSC the Minimad over wifi (connected to wifi, no ethernet cable). Is there a way to do it ? Of course, I could do it buy plugin the Minima to a wifi router using ethernet, but this is not what I need.
    In the manual, it seems to be over ethernet, and what I remember when I used few years ago a blue version, they were no option to configure wifi credentials (or did I missed something ?)
    Thanks in advance for your answer.
    Re: Minimad OSC over Wifi ?
    by Pierre Guilluy » Wed Sep 26, 2018 6:10 pm
    For the moment you can do that by using an Ethernet + Wifi router with DHCP functionality.
    The blue or black miniMAD both feature Ethernet connectivity only.
  • volt'air
    by volt'air » Thu Oct 04, 2018 6:58 pm
    Pierre,
    Thank you for your answer. So, if I need to use an ethernet cable to the router, it will be useless for the project (as it as to be as "free from cables" as possibly as I can). Do you plan to put this fonction in the future ?
    Thanks again !
    by Pierre Guilluy » Thu Oct 04, 2018 9:38 pm
    I guess you can also configure a Raspberry Pi 3 to act both as a DHCP server over ethernet and Wifi access-point.
    By connecting the miniMAD and the Raspberry Pi using a short ethernet cable, you would retain a compact setup while gaining wireless control.
  • volt'air
    by volt'air » Sat Oct 06, 2018 9:28 pm
    Thanks Pierre. I will take a look to this solution.
