Is there a way to Linear Transition the Input Positions?
  • ruvidan
    by ruvidan » Fri Sep 28, 2018 7:34 pm
    When I create two scenes or cues, the transition duration has been a blast with regards to slowly tweening (animating) the difference between two settings. One thing I haven't been able to figure out. I'd like have the "Input Pos", "Input Size", "Input Rot" animated, but I can't seem to figure out how to do that. Is it possible or is this something that will happen in a future update? Thanks!
    Re: Is there a way to Linear Transition the Input Positions?
    by mad-matt » Wed Oct 03, 2018 9:17 am
    The cues are storing the input geometry, so a combination of "Input Pos", "Input Size", "Input Rot". You can't store them independently. It would not make sense for some surfaces.
