Midi connection to Computer
  • Alma
    by Alma » Tue Aug 15, 2006 10:26 pm
    Hi Guys and Girls
    So I'm going to use the new Acoustic Drum Triggers (RT-10K/S/T) to trigger video from drums.
    I will connect them to a ROLAND TMC-6 TRIGGER MIDI CONVERTER..
    And now for the big dumb question - How do I connect the TMC-6 to my computer and to the modul8????????
    I've never used a midi before so please, please, please try to explain so I will understand..
    What kind of cable?
    I'm using a MAC Lap TOP G4 1.5 ghz.
    It runs the modul8 great.
    Will it be harder with the midi?
    THANK YOU!!!
    Alma
    almaharel.com
    by sigmasix » Wed Aug 16, 2006 1:32 am
    you need a midi interface (midi <-> usb), m-audio has some good ones! then it's really easy to configure modul8
  • Alma
    by Alma » Wed Aug 16, 2006 4:40 am
    Do you mean some thing like the: M-Audio Midisport 2x2 (Macintosh and Windows)?
    http://www.zzounds.com/item--THKMIMMS22
    Is this a good one?
    by sigmasix » Wed Aug 16, 2006 11:04 am
    good one, I don't know but it will work of course! you don't really need an expensive interface if cheaper works too :wink:
  • jm302
    by jm302 » Wed Aug 16, 2006 5:52 pm
    Greetings,
    I have a M-audio UNO http://www.zzounds.com/item--MDOUNO that works just fine with all my apps that use MIDI, including M8. Using a device like this should have no noticeable impact on your computer's performance.
    Cheers,
    Justin
    http://www.302acid.com
  • Alma
    by Alma » Fri Aug 18, 2006 11:45 am
    Thank you so much guys and Girls!
    Any last tips or thoughts on how to work with the drum triggering?
    I heard they can be too fast for the video.. :shock:
