Madmapper not recognizing Leapmotion
  • ruvidan
    by ruvidan » Sun Oct 07, 2018 7:37 pm
    Hey all. Just got a leapmotion controller. Calibrated it. Opened mad mapper, went to preferences and checked the"Enable leapmotion support". Added a custom control, but none of the leapmotion controls seem to be registering or working. I've tried reinstalling leapmotion and also tried the beta version of Madmapper. Just cant get madmapper to see it. THe visualizer on leapmotion shows my hands are being registered. Any thoughts?
  • ruvidan
    Re: Madmapper not recognizing Leapmotion
    by ruvidan » Mon Oct 08, 2018 3:23 am
    I've been reading, and it looks like leapmotion have 2 versions. I have the latest version. is the Leapmotion support only for the old, legacy versions?
    by mad-matt » Wed Oct 10, 2018 10:04 am
    Normally LeapMotion will work with active application. But maybe they changed something. Please try to reboot, not start any other leap motion enabled application, but just start MM. Does it help ?
  • rongomai
    by rongomai » Sat Oct 31, 2020 12:06 pm
    For future users who can't get their leap motion to work...
    This version of leap motion software worked for me.
    Specs:
    Win10 - latest updates @ 31 Oct 2020
    Leap V1 hardware.
    https://developer.leapmotion.com/releas ... -orion-321
    LeapDeveloperKit_3.2.1_win.zip
    Total size: 484 MB
  • HALLABO
    by HALLABO » Sat Feb 22, 2025 6:50 pm
    I tried to connect LeapMotion and operate MadMapper, but I couldn't get the value.
    Specifications
    Win11
    MadMapper 6.0.0 Beta6
    Leapmotion (LM-C01-JP)
    Install the Leapmotion driver (v5.20.0) from the following site.
    https://leap2.ultraleap.com/downloads/l ... ontroller/
    Confirm that Leapmotion works from the included app (Ultraleap Control Panel).
    [MadMapper Settings]
    Check "Enable Leap Motion support" from Preferences and restart MadMapper.
    Refer to the following site to set Leapmotion in the Control List.
    https://www.youtube.com/watch?v=8Uph1eOVTjo
    1. Select the Other tab
    2. Select surfaces - Circle-1 - output - x in that order
    3. Change the Target range to 0 to 1920
    [Operation on MadMapper]
    The sensor does not pick up any values, and the Source range does not move from the default value (-500 to 500).
    No error screen is displayed.
    Around June 2021, values ​​could be obtained in a MadMapper 4.0.3 + Win10 environment.
    I installed MadMapper 4.21 and checked the operation in a Win11 environment, but the same situation occurred.
    by mad-matt » Tue Feb 25, 2025 11:58 am
    MadMapper supports an old Leap Motion SDK. Check this post: viewtopic.php?t=10651#post_content61945
