Using 5760x1080 video file and it's bit lagging
  • kfreesp
    by kfreesp » Wed Oct 17, 2018 2:54 pm
    Hello :)
    I'm using Madmapper 3 but I'm having a trouble with playing large resolution video file.
    Problem : Audio and Video are lagging and not synced.
    Spec of my PC is like below
    - PC spec
    CPU : Intel i7 8700
    GPU : gtx 1060 D5 3Gb
    RAM : 4GB
    OS : windows 10
    - video Output : 4
    3 Projector output (where video is being sent)
    1 Monitor (to use and check Madmapper)
    - File
    resolution : 5760 x 1080
    file format : mp4
    codec : I don't know about the codec yet... but I supposed it might be Mpeg or something. ( I can re-render this hopefully )
    I'm trying to use HAP code if I can do it ! but is that possible to use HAP codec in Windows 10?
    thanks!
    Re: Using 5760x1080 video file and it's bit lagging
    by mad-matt » Thu Oct 25, 2018 2:17 pm
    Please use MadMapper 3.6.0 (free update), it supports hardware decoding of HAP, Hap Alpha and HapQ on Windows and macOS.
