Chauvet epix drive 640
  • Rawdogct
    by Rawdogct » Thu Oct 18, 2018 1:52 am
    Got 32 strips and 2 640's. Cant figure out how to map or find a profile. Been using media master but dont care for the fx or loops. Want more fixture based fx like mad mapper and not run video loops on them.
    Re: Chauvet epix drive 640
    by mad-matt » Thu Oct 25, 2018 2:16 pm
    Not clear what you want to setup. You have 32 RGB strips each 2640 pixels long ?
    What will you do with the strips ? Just dispose them in the space without cutting them ? In this case, you have to use the Fixture Editor (from menu Tools) to create a fixture definition of Nx1 pixels with pixel type set to RGB. Then add a fixture in your project and choose this fixture definition, and setup the right DMX address (and the correct DMX interface in Preferences / DMX Out)
  • Rawdogct
    by Rawdogct » Sat Feb 16, 2019 10:26 pm
    No I have 32 chauvet epix strips running off of 2 epix drive 640 drivers. 16 strips per driver. each strip is 40x3(rgb)=120 pixels each. I cant get the profile right for 1 strip much less to set up all 32. Media Master sees them no problem and have run through that fine, but I don't like the control options for playback. I would rather control them more as a light fixtures, than more like a video wall.
    by mad-matt » Sun Feb 17, 2019 9:24 pm
    About the "epix drive 640" driver from Chauvet: Controlled via ArKaos Kling-Net Protocol / Requires MediaMaster on Mac or PC
    Chauvet did a partnership with arKaos, who developped this closed protocol Kling-Net. We can't deal with that. MadMapper supports the two standard protocol of the market: ArtNet and sACN. Only a few companies work with Kling-Net protocol.
  • Rawdogct
    by Rawdogct » Wed Feb 20, 2019 7:07 pm
    Ok. Didnt realize it was actually a kling net only device. Would there be any work arounds you think that could work either hardware or software?
    by mad-matt » Wed Feb 27, 2019 1:22 am
    No idea...
Users browsing this forum: Baidu [Spider] and 30 guests
