Monome
    pele2010
    Monome
    by pele2010 » Mon Oct 29, 2018 7:32 pm
    I own a Monome 64 and I am asking myself: is there a way to use it with modul8 3.0?
    Has anyone a working module?
    Would be great to know .
    thanxs
    Peter
    www.instagram.com/pele2010/
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • geoffmatters
    Re: Monome
    by geoffmatters » Tue Oct 30, 2018 3:05 am
    Have you tried "Monomal" from the public library?
    It describes itself as a "very complete module" including sequencer, media assignment, etc
    pele2010
    Re: Monome
    by pele2010 » Tue Oct 30, 2018 11:12 am
    Yes I worked with monomal but since the update to 3.0
    it crashes ?
    Is there an update to the module?
    thanxs Peter
    #eachfilm01
    #pele2010
    www.eachfilm.de
  • geoffmatters
    Re: Monome
    by geoffmatters » Wed Oct 31, 2018 4:08 am
    The module's info contains the email address of the author (you can view info in the editor or in the public library browser) I'd suggest mailing them. I have a monome in my closet but I've never tried it with M8...
  • Donleavy
    Re: Monome
    by Donleavy » Tue Jun 01, 2021 12:17 am
    You can of course always use a Max patch to send MIDI to Bidule.
    I am still using monome_midi_64.maxpat to simply send key presses to Modul8 in order to map monome buttons to buttons in Modul8. The patch is a bit simple and there were other patches available with press/toggle functions but they don't work anymore. I have recently written to Monome to ask for a new, simple Max patch to pass on MIDI notes/ctrl to other applications. There's a good chance that they will come up with something...
    /Dl
