Audio signal-controlled fader Module?
  • xno
    by xno » Fri Sep 01, 2006 5:08 am
    Greetings. I´d like to know if its feasible to do a Module where the audio input signal controls the fader position between banks A and B. Maybe there is already one out there?
    That would be better...I use the application very superficially and programming new modules is way out of my league. But who knows, maybe this is a good opurtunity to learn!
    Thanks in advance.
    Record>Splinter>Scramble
    www.xnografikz.com
  • Lupin
    Re: Audio signal-controlled fader Module?
    by Lupin » Fri Sep 01, 2006 1:16 pm
    xno wrote:Greetings. I´d like to know if its feasible to do a Module where the audio input signal controls the fader position between banks A and B. Maybe there is already one out there?
    Thanks in advance.
    I just built it for you ;)
    check on the online public library and download the
    M-VS_SOUND_CROSSFADER
    I also released a new version of my sound viewer module (more compact)
    cheer
  • xno
    Great!
    by xno » Fri Sep 01, 2006 3:58 pm
    Jeez, I didn´t expect this...thank you so much, I´ll give it a try today!
    Let me know if I can help you in the same way (with something that I know how to do he he)
    Best,
    Arturo
    www.xnografikz.com
  • xno
    OK
    by xno » Fri Sep 01, 2006 5:13 pm
    Works great, thnx Lupin...[/list]
    www.xnografikz.com
  • Lupin
    by Lupin » Fri Sep 01, 2006 5:34 pm
    you are welcome ;)
    if you wanna get higher drop values, simply change the max value of the pot on the visual tab of the editor
    and if you want to affine the jerkyness of the crossfade you can use round values in the script part in the Periodical Event(elapsed) part:
    ex:
    Code: Select all
    if start ==1:
       if boostmode ==0:
          soundvalue = modul8.getValue('direct_soundCaptureLevel',0)
       else:
          soundvalue = modul8.getValue('direct_soundCaptureLevel',0)* boostvalue
       modul8.setValue('ctrl_master_crossfader_slider',round(soundvalue,2),10)
       module.setValue('bsnd',0,soundvalue)
    the rounded part of the code is
    Code: Select all
    if you want a radical effect like a show/hide way change it to
    Code: Select all
    modul8.setValue('ctrl_master_crossfader_slider',round(soundvalue),10)
    then after if you are familiar with math algorythms you can either import the math package and do your own custom transitions
    have fun :)
  • xno
    direct cut
    by xno » Fri Sep 01, 2006 8:06 pm
    Neato.
    So if I want the transitio to be more of a cut between the two banks this is the way to go.
    I´ll have to do some serious study of the user´s manual...I suck at math & coding :-(
    Best,
    Arturo
    www.xnografikz.com
  • Lupin
    Re: direct cut
    by Lupin » Fri Sep 01, 2006 8:34 pm
    xno wrote:Neato.
    Best,
    Arturo
    don't worry :)
    i updated the module and I added 3 m different cuts
    refresh your module list and get the 1.1version
    Best,
    Gael
  • xno
    Yay!
    by xno » Fri Sep 01, 2006 8:46 pm
    You´re THE MAN.
    Thnx :-D
    www.xnografikz.com
