is a per layer mask module possible in 2.5?
  • eskatonia
    by eskatonia » Sat Sep 09, 2006 4:19 pm
    I've just started looking at the scripting possibilities to see if I could make a per layer mask option.
    I'm not sure its possible, there is no proper blend modes (eg multiply) that I could use to mask one layer only.
    do we have to wait for 3.0 to be able to make a module for this feature?
    this is really important to me, if I can't do layer masks I can't use modul8 in most of the gigs I do (shaped screen clusters)
  • Lupin
    by Lupin » Sun Sep 10, 2006 11:07 am
    your question is important. but i'm not sure individual masks are implemented yet.
    have you tried to create a routine with quartz composer?
    cal6n
    by cal6n » Sun Sep 10, 2006 3:42 pm
    I know the sort of thing you're looking for, specifically hexagons!
    I've not found a way of doing these but you can do squares with the "crop(m8)" filter. This doesn't solve your problem but maybe a "polygon crop" filter could be written within the filter module with "centre", "sides", "size" & "angle" parameters.
    The scripting is way beyond me, I'm afraid, but maybe some kind soul could help out?
  • tape recorder
    by tape recorder » Sat Nov 11, 2006 6:22 am
    I've been experimenting with a work around using the key feature but nothing satisfactory... I could really use this also
  • Larky
    by Larky » Thu Sep 13, 2007 8:54 pm
    Ågreed, this is a major requirement. We need more than hex's though, as we'll all soon get bored of them!
    I'm playing with Quartz as a workaround for the moment, also vvvv. Hopefully I'll have something soon.
Users browsing this forum: Baidu [Spider] and 25 guests
