Auto Scale will not react to sound in
  • Alma
    by Alma » Thu Sep 14, 2006 3:03 am
    I'm using modul8 on a powerbook.
    I know the sound in through internal mic used to work on my old modul8 version.
    I upgraded and now when I test the sound in with some clapping or music nothing happens.
    (I'm trying to use the Auto Scale with sound in from the powerbook mic)
    Any ideas why?
  • Akira
    by Akira » Thu Sep 14, 2006 8:14 am
    Is the mic enabled in the system Preferences?
    Is the "Sound In" knob in modul8 turned on?
    Is your microphine working properly? My iBook's microphone stopped working after a while, all that open and closing of the lid screws up the cable.
    Cheers,
  • collett
    by collett » Sun Sep 17, 2006 6:49 pm
    you have to restart modul8 after changing sound settings in sys preferences as well. have you tried putting a mini jack input (external mic/ipod) in to the mac, if that works then i guess you can confirm that it is a problem with the mic rather than modul8.
Users browsing this forum: No registered users and 70 guests
